08/04/20, 08:23 AM
Author Topic: Dirt Track Dust  (Read 3511 times)
Junior
  • Guest
Dirt Track Dust
« on: 10/29/09, 08:24 PM »
Some dirt tracks that I downloaded has so much dust that you can't see. Example is Limaland dirt track and Augusta 63. Is there a way in the config file to change the amount of dust the track has? Thanks
Re: Dirt Track Dust
« Reply #1 on: 10/29/09, 08:29 PM »
No, it's the way the track is created that has more or less dust... The tracks with a lot of dust actually use the dirt surface in the track, and the ones that don't have as much dust use the grass surface with a 'dirt' texture applied to it. The result is a slippery surface that looks like dirt, but doesn't make any dust. Then they alternate between a dirt surface and a grass surface to make the dust show up every once in a while.
Junior
  • Guest
Re: Dirt Track Dust
« Reply #2 on: 10/29/09, 08:34 PM »
Hey thanks Robert. You saved me a lot of time in the config file. Can't wait til your dirt mod comes out.
Regards
Lamar Wright
cam5
  • Guest
Re: Dirt Track Dust
« Reply #3 on: 10/29/09, 08:36 PM »
 If you go into options, then the graphics tab and uncheck the debris and particles the dust will be gone.
thats the only way I was able to run at those tracks. Other that it's like Robert said.
Junior
  • Guest
Re: Dirt Track Dust
« Reply #4 on: 10/29/09, 08:43 PM »
Thanks Cam5, I'll give it a try!!
Regards
Lamar Wright
Re: Dirt Track Dust
« Reply #5 on: 10/29/09, 09:04 PM »
Good tip! I forgot all about that!
WillG
  • Guest
Re: Dirt Track Dust
« Reply #6 on: 11/01/09, 11:06 PM »
I love to do 100 lap endurance races at Augusta 1963. lol.
