07/12/20, 11:55 PM
Author Topic: Cup90 - 1995 Winston Cup Expansion set  (Read 3740 times)
Offline ongias25
  • Coolness: 27
Re: Cup90 - 1995 Winston Cup Expansion set
« Reply #20 on: 03/09/19, 11:15 AM »
Mike, can't tell you how much I appreciate you doing these cars. Great job!
Offline psugorilla
  • Coolness: 5
« Reply #21 on: 03/10/19, 05:36 PM »
And now there are only 2 cars left to paint!  :Woot_Emoticon:
Offline psugorilla
  • Coolness: 5
« Reply #22 on: 03/12/19, 04:03 PM »
Set is done!
Tweaking some ratings here and there and doing a bit of testing before release.
This will be a full 1995 carset release and will be replacing the existing set.
I received permission from CC#48 to use his existing set with mine.
Offline ongias25
  • Coolness: 27
« Reply #23 on: 03/13/19, 01:46 PM »
Considering the amount of research that you had to do and the way you crank these cars out you got these done very very fast. Really appreciate all your work and dedication on completing these!
Offline psugorilla
  • Coolness: 5
« Reply #24 on: 03/18/19, 08:05 PM »
Hey guys! Just wanted to pass along that the set is finished and released. It can be downloaded at Stunod or at the following link.
http://www.mediafire.com/file/wsuda1130nhboyr/1995+Winston+Cup+Carset.zip
Robert, if you wish to host the set here with the others feel free.
I hope you all enjoy the set. Many thanks goes out to Chris (CC#48) for his original set and allowing me to use those cars in conjunction with mine to make the most complete 1995 set possible.
In all 149 cars and every driver to officially qualify for a race and the vast majority who DNQ'd are included. (Only 4 DNQ's are not represented)
Offline ongias25
  • Coolness: 27
« Reply #25 on: 03/19/19, 12:25 AM »
Thanks so much for all the work that went into doing these and for sharing!
« Reply #26 on: 05/01/19, 12:43 PM »
Thanks for all your work, and sharing these here Mike! I'll get them posted this weekend. Great work!
