Welcome, Guest. Please login or register.
09/28/20, 07:09 PM
Author Topic: A suggestion  (Read 2190 times)
0 Members and 1 Guest are viewing this topic.
Offline Randy C
  • Veteran Driver
  • Coolness: 12
A suggestion
« on: 09/03/13, 09:42 AM »
I had a thought. Would it be feasible to make an add-on of some sort to give NR 2003 the ability to finish races under the green-white-checkered rule they have in NASCAR now?  I hate finishing races under caution. What do you think?
Randy C
Offline Sage
  • Racin Grafix Painter
  • Veteran Driver
  • Coolness: 58
    • Acme Signs
Re: A suggestion
« Reply #1 on: 09/03/13, 03:31 PM »
From other discussion that I've read about this it isn't possible to do without hacking the .exe.
I went outside once. The graphics weren't all that great.
I suffer from CDO. It's like OCD, but in alphabetical order, LIKE IT SHOULD BE!
If you can't spill it, it ain't 'paint'!
Offline Randy C
  • Veteran Driver
  • Coolness: 12
Re: A suggestion
« Reply #2 on: 09/03/13, 06:39 PM »
Thank you for the answer, Sage.  I am not a computer whiz nor will I ever be.  I know where to put the NR 2003 season disc when I want to race. :)
Randy C
Offline Sage
  • Veteran Driver
  • Coolness: 58
    • Acme Signs
Re: A suggestion
« Reply #3 on: 09/04/13, 03:13 AM »
You should get the NoCD patch and then you won't need to risk damaging your disc. I've got 7 different installs of NR2003 and none of them need the disc. I'd direct you to a download but, depending on your OS (Operating System...XP, Vista, Win7, Win8), there may be additional steps you'll need to take to get it to work. Just Google: NR2003 NoCD and a bunch of results will kick up. Look for a result that mentions your OS.
Offline Randy C
  • Veteran Driver
  • Coolness: 12
Re: A suggestion
« Reply #4 on: 09/05/13, 08:20 PM »
Thanks, Sage.  I have Windows 7.  I will check into this.
Randy C
