08/21/19, 10:24 AM
Author Topic: TRACK 1990  (Read 4115 times)
Offline NeoDart28
  • Coolness: 15
  • ANIME RACING
    • Racin Grafix
TRACK 1990
« on: 06/10/12, 03:55 PM »
hi need where find old Martinsville 1990?
Offline ongias25
  • Coolness: 27
Re: TRACK 1990
« Reply #1 on: 06/11/12, 10:12 PM »
http://www.freewebs.com/trackdownloads/1990trackdownloads.htm     You can find it here,I believe its a texture update but is the only one I know of.
Offline Krusty
Re: TRACK 1990
« Reply #2 on: 06/12/12, 08:06 PM »
Put the file (trackmat) into the Atlanta 1997 track folder. Changes the wall color to red and white stripes.
Offline ongias25
  • Coolness: 27
Re: TRACK 1990
« Reply #3 on: 06/12/12, 11:49 PM »
He is looking for Martinsville 1990,not Atlanta.You need Martinsville 1998 then put the trackmat folder in the Martinsville 98 folder and your all set.
Offline Krusty
Re: TRACK 1990
« Reply #4 on: 06/13/12, 12:44 PM »
Must be old age.  I have no idea of why I put Atlanta.  :-[
Offline ongias25
  • Coolness: 27
Re: TRACK 1990
« Reply #5 on: 06/13/12, 03:14 PM »
No worries,I am 50.Been there,done that!
Re: TRACK 1990
« Reply #6 on: 06/14/12, 01:55 AM »
50? P'shaw! You's a baby!
Offline ongias25
  • Coolness: 27
Re: TRACK 1990
« Reply #7 on: 06/14/12, 03:56 AM »
Thank you Sage.And thank you for all that you do for us racers.Phil
Offline NeoDart28
  • Coolness: 15
  • ANIME RACING
    • Racin Grafix
Re: TRACK 1990
« Reply #8 on: 06/19/12, 12:10 PM »
really that Martinsville 98?
Offline ongias25
  • Coolness: 27
Re: TRACK 1990
« Reply #9 on: 06/19/12, 03:35 PM »
Yes, Martinsville 98.It is a texture update only,so I'm assuming the track looked pretty much the same in 1998 as it did in 1990 with the exception of billboards and the color of the walls.
