02/20/20, 03:07 PM
Author Topic: best pta mod  (Read 2389 times)
Offline Corey Carpenter
  • Coolness: 7
best pta mod
« on: 02/08/10, 09:39 PM »
i like to road race in nr2003.... and i was wondering what is the best road racing mod out there
im currently using the trans am mod... i like it, but i wonder if there is a better mod for road racing
When Davey Allison went to heaven, he was met at the gate by Alan Kulwicki.  Behind Alan, Davey could see the #7 and #28 cars.  Alan said "Man this place is great.  The cars are setup perfect!"  Then Davey saw the #3 car and exclaimed  "Oh No!  Not Dale too!"  Alan said "No, THAT'S the car God races
Offline bobbyisaac
Re: best pta mod
« Reply #1 on: 02/10/10, 08:07 PM »
I once had a version of the GTP mod in PTA phyiscs and that was a blast to drive.
Re: best pta mod
« Reply #2 on: 02/11/10, 02:12 AM »
Depends on what you want to drive... there's a few different PTA physics mods, but only a few. Check the list over at www.nr2k3tracks.com for most of them.
If you get a notion to install GTP, it takes a separate install of NR2003 to run it, or it will overwrite your EXE file and you won't be able to run regular mods anymore and you will have to reinstall.
Now the GTP with PTA physics mentioned above shouldn't do that.
Offline bobbyisaac
Re: best pta mod
« Reply #3 on: 02/18/10, 01:07 PM »
Yeah the GTP with PTA physics was personally modded by me on a tutorial i saw somewhere. Thing was fun but a pain. There is no ( nor ever should be ) a public version of that.
Offline RBaller
  • Jackman
Re: best pta mod
« Reply #4 on: 02/20/10, 07:46 PM »
i have a question about the pwf trans am mod..........how come when i get into fifth gear it just goes straight to over rev and samething for 6th gear?? what can i do to fix it so i can full usage outta all 6 gears??
Offline Gchap
  • Coolness: 16
Re: best pta mod
« Reply #5 on: 02/20/10, 09:48 PM »
You can d/l GTP with pta at 3MN5's Forum.
Re: best pta mod
« Reply #6 on: 02/21/10, 04:06 AM »
You just need to adjust the gearing in your setup
Offline RBaller
  • Jackman
Re: best pta mod
« Reply #7 on: 02/21/10, 11:23 AM »
thanks for the help guys. :13:
